Doitmyself
#1 Posted : 18 years ago
Doitmyself
My GE (electric) dryer makes a high pitched squeaking sound about 1 time per second. It sounds like it is coming from a place near the back of the dryer, and I believe I need to replace the rear drum bearings.
Am I on the right track? My other problem is that I am not sure how to access the rear drum. Do I need to remove the 3 hex nuts inside the drum, to release it from the bearings?
Any suggestions would be welcome.
#2 Posted : 18 years ago
Doitmyself
Pull the dryer from the wall. In the center of the rear panel you'll find a rectangle metal cover holding by two 5/16" screws. Behind this cover is the rear drum bearing. Put a few drops of a machine oil inside the bearing and it should stop the noise.
Good luck.
jdman
#3 Posted : 18 years ago
jdman
I find that lubericating only buys a little time. Not long before replacing it anyway
Dryer Repair Again and Again (Dryer Repair)
by Guest 3 years ago
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 3 years ago
Dryer repairs (Dryer Repair)
by P3FE 3 years ago
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 5 years ago
Dryer Repair Issue (Dryer Repair)
by jdharrin 6 years ago
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 7 years ago
Dryer repair Help! (Dryer Repair)
by Hah45 7 years ago
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 9 years ago
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 9 years ago
Dryer Repair (Dryer Repair)
by sotomargie 9 years ago
Dryer repair (Dryer Repair)
by dchurch 10 years ago
by jaybick 10 years ago
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10 years ago
by Tom Campion 11 years ago
by kencorey281@gmail.com 11 years ago
