Doitmyself
#1 Posted : Tuesday, July 24, 2007 11:45:07 AM(UTC)
Doitmyself
My GE (electric) dryer makes a high pitched squeaking sound about 1 time per second. It sounds like it is coming from a place near the back of the dryer, and I believe I need to replace the rear drum bearings.
Am I on the right track? My other problem is that I am not sure how to access the rear drum. Do I need to remove the 3 hex nuts inside the drum, to release it from the bearings?
Any suggestions would be welcome.
#2 Posted : Thursday, July 26, 2007 7:44:04 PM(UTC)
Doitmyself
Pull the dryer from the wall. In the center of the rear panel you'll find a rectangle metal cover holding by two 5/16" screws. Behind this cover is the rear drum bearing. Put a few drops of a machine oil inside the bearing and it should stop the noise.
Good luck.
jdman
#3 Posted : Friday, July 27, 2007 12:13:18 PM(UTC)
jdman
I find that lubericating only buys a little time. Not long before replacing it anyway
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
Belarus try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
