Replaced timer purchased from yall, Ive replaced power cord,check breakers.ok .what next?:eek:
need help with dryer......wont start.......replaced power cord,timer and checked breakers there fine..........help
Here are your parts includes a wiring diagram Model CDE6000WFollowing is the start up circuit path. NEUTRAL , THERMAL FUSE NON RESETTABLE , DOOR SWITCH , MOTOR PROTECTOR , motor's RUN and AUX windings , timer contacts L/M , L1 Most likely culprit is the thermal fuse. Unplug the machine and measure it with a meter (0 ohms with at least one wire removed) If you do not have a meter, short the two wires together, tape them up so they cannot short to anything and give it a try. If it runs replace the fuse ASAP as it is a safety device. Note if it is the fuse be sure to clean and check your vent system, this is the most common cause of a blown fuse. Next would be the door switch. Note that just because it may click and you think it is closed does not mean that the actual contacts in the switch have closed. |
THIS FORUM IS DEAD!!!!!!! |
where are the fuses located? I found the big one but where is the smaller one .
This unit only has one thermal fuse, should be on the heater.
Also has thermostats mounted on the blower assembly.
Sorry for the delay but have been at the lake.
denman |
