trish63
#1 Posted : Thursday, January 29, 2009 10:26:12 AM(UTC)
trish63
Replaced timer purchased from yall, Ive replaced power cord,check breakers.ok .what next?:eek:
trish63
#2 Posted : Thursday, January 29, 2009 10:28:11 AM(UTC)
trish63
need help with dryer......wont start.......replaced power cord,timer and checked breakers there fine..........help
#3 Posted : Thursday, January 29, 2009 2:14:58 PM(UTC)
Here are your parts includes a wiring diagram
Model CDE6000W
Following is the start up circuit path.
NEUTRAL , THERMAL FUSE NON RESETTABLE , DOOR SWITCH , MOTOR PROTECTOR , motor's RUN and AUX windings , timer contacts L/M , L1
Most likely culprit is the thermal fuse.
Unplug the machine and measure it with a meter (0 ohms with at least one wire removed)
If you do not have a meter, short the two wires together, tape them up so they cannot short to anything and give it a try.
If it runs replace the fuse ASAP as it is a safety device.
Note if it is the fuse be sure to clean and check your vent system, this is the most common cause of a blown fuse.
Next would be the door switch. Note that just because it may click and you think it is closed does not mean that the actual contacts in the switch have closed.
molney
#4 Posted : Thursday, August 6, 2009 7:31:40 AM(UTC)
molney
where are the fuses located? I found the big one but where is the smaller one .
#5 Posted : Tuesday, August 11, 2009 5:43:25 AM(UTC)
This unit only has one thermal fuse, should be on the heater.
Also has thermostats mounted on the blower assembly.
Sorry for the delay but have been at the lake.
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
maytag legacy dryer wont start (Dryer Repair)
by kennypkay 11/15/2015 2:02:45 PM(UTC)
Admiral Dryer wont start (Dryer Repair)
by chargitt 8/24/2015 1:25:34 PM(UTC)
kenmore dryer wont start (Dryer Repair)
by coindog1 7/26/2015 12:33:16 PM(UTC)
by antoine123 6/10/2015 5:23:52 PM(UTC)
dryer contol lock is locked -dryer wont start (Dryer Repair)
by k62254 5/29/2015 1:10:18 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Whirlpool dryer wont start (Dryer Repair)
by laundry1 1/20/2015 11:46:37 AM(UTC)
dryer wont start (Washer Repair)
by rangerleader63@gmail.com 9/4/2014 7:56:01 AM(UTC)
by mich01 9/1/2014 4:17:03 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
by cnrimgr1 2/17/2014 12:27:23 PM(UTC)
