wit0066
#1 Posted : 14 years ago
wit0066
voltage low at connection plug for ice maker 105v instead of 115v. unit was working than stopped. unit works good on bench. wall outlet reads 115v where frig is plugged in. losing 10 volts somwhere in ice maker circuit Bum dope no voltage at unit believe a external (not on unit) thermostat must supply voltage when freezer is at proper temp. I turned temp up to see what will happen was told my another tech that unit should operate at 105v anyhow. I was using a sensitive flute meter and once I put a light bulb on feed wires no light and no voltage. no print so I am guessing
#2 Posted : 14 years ago
I'm afraid I did not get clear where did you get 105 VAC reading?
What is the status of the LED on the right side when you close the emitter door?
Maytag french door refrigerator icemaker problems (Refrigerator & Freezer Repair)
by jamie_pancake@yahoo.com 10 years ago
KitchenAid Model model# KSCS25FKSS01 icemaker problem (Refrigerator & Freezer Repair)
by jwagd07 12 years ago
IceMaker problems (Refrigerator & Freezer Repair)
by leenorm422@aol.com 12 years ago
Icemaker problems (Refrigerator & Freezer Repair)
by jamosteve 13 years ago
GE refrigerator icemaker problem (Refrigerator & Freezer Repair)
by bdale02m 13 years ago
Amana icemaker problem (Refrigerator & Freezer Repair)
by jaguar301 13 years ago
Icemaker problem - replaced fill valve already (Refrigerator & Freezer Repair)
by djneil1 13 years ago
Whirlpool Gold Icemaker problem (Refrigerator & Freezer Repair)
by bwatty 14 years ago
GE Icemaker problems (Refrigerator & Freezer Repair)
by kjp1015 14 years ago
by wit0066 14 years ago
Whirlpool Icemaker problems (Refrigerator & Freezer Repair)
by mw_98 14 years ago
by VOLLER 15 years ago
ge profile icemaker problem (Refrigerator & Freezer Repair)
by lwilliams 15 years ago
Weird Icemaker problem (Refrigerator & Freezer Repair)
by hoginokc 15 years ago
by AustinBrooks 16 years ago
