jaguar301
#1 Posted : Tuesday, June 12, 2012 5:54:04 AM(UTC)
jaguar301
I replaced the icemaker (Part number: D7824706Q
) and the new unit has the same problem as the old one in that it will not fill with water. If I manually add water the unit makes ice. I put and jumped between test holes V and L and sufficient amount of water enters the icemaker (7 seconds allows approx 140cc of water). I checked the temperture of the freezer and it is zero degrees. Can you help me diagnose my problem? Thanks, John
