hoginokc
#1 Posted : Tuesday, February 2, 2010 3:51:36 PM(UTC)
hoginokc
OK, a couple of says ago, I noticed our icemaker was not producing ice. After "googling" I found this site, and proceeded to go through some of the troubleshooting I found.
[LIST=1]
  • Verified the water dispenser on the door worked, it did.
  • Filled the icemaker tray manually, and the unit produced and dumped ice.
  • Checked the fill line to see if it was frozen. It wasnt but I warmed it with a hair dryer anyway, just in case.
  • Again, I noticed, the water was never kicking on.
  • I decided that it was probably the water valve on the back.
  • Decided to pull the fridgeout just to look. While I had the unit out, I noticed how filthy it was behind it, and began to sweep the area. I noticed no crimps or anything.
  • Whadya know, while I was sweeping the water kicked on and filled the maker. I pushed it back in. It did not fill again. This morning I pulled it about half way out, you guessed it, the wife said it filled and dumped all day, which was obvious looking in the tray. I pushed it back in when i got home. Since then I have observed the maker twice....going thru the motions, with no ice becasue there was no water. I've since pulled it back out some to see if it fills again.
  • Any thoughts, ideas? I'm still thinking valve, but don't know.[/LIST]
    Thanks in advance,
    Scott
  • Sponsor
    hoginokc
    #2 Posted : Wednesday, February 3, 2010 8:09:57 AM(UTC)
    hoginokc
    after pulling the fridge out, it made ice all night..............grrrrrrrrrrrrrrrrrrr
