wit0066
#1 Posted : Thursday, May 5, 2011 11:09:27 AM(UTC)
wit0066
voltage low at connection plug for ice maker 105v instead of 115v. unit was working than stopped. unit works good on bench. wall outlet reads 115v where frig is plugged in. losing 10 volts somwhere in ice maker circuit Bum dope no voltage at unit believe a external (not on unit) thermostat must supply voltage when freezer is at proper temp. I turned temp up to see what will happen was told my another tech that unit should operate at 105v anyhow. I was using a sensitive flute meter and once I put a light bulb on feed wires no light and no voltage. no print so I am guessing
#2 Posted : Thursday, May 5, 2011 1:56:10 PM(UTC)
I'm afraid I did not get clear where did you get 105 VAC reading?
What is the status of the LED on the right side when you close the emitter door?
Maytag french door refrigerator icemaker problems (Refrigerator & Freezer Repair)
by jamie_pancake@yahoo.com 8/13/2015 3:44:09 AM(UTC)
KitchenAid Model model# KSCS25FKSS01 icemaker problem (Refrigerator & Freezer Repair)
by jwagd07 3/18/2013 6:41:34 PM(UTC)
IceMaker problems (Refrigerator & Freezer Repair)
by leenorm422@aol.com 2/16/2013 11:33:47 AM(UTC)
Icemaker problems (Refrigerator & Freezer Repair)
by jamosteve 9/24/2012 3:17:52 PM(UTC)
GE refrigerator icemaker problem (Refrigerator & Freezer Repair)
by bdale02m 8/21/2012 5:55:11 PM(UTC)
Amana icemaker problem (Refrigerator & Freezer Repair)
by jaguar301 6/12/2012 5:54:04 AM(UTC)
Icemaker problem - replaced fill valve already (Refrigerator & Freezer Repair)
by djneil1 10/21/2011 9:01:28 AM(UTC)
Whirlpool Gold Icemaker problem (Refrigerator & Freezer Repair)
by bwatty 8/29/2011 1:44:58 PM(UTC)
GE Icemaker problems (Refrigerator & Freezer Repair)
by kjp1015 7/27/2011 4:13:24 PM(UTC)
by wit0066 5/5/2011 11:23:21 AM(UTC)
Whirlpool Icemaker problems (Refrigerator & Freezer Repair)
by mw_98 2/13/2011 5:47:44 AM(UTC)
by VOLLER 8/4/2010 6:14:58 AM(UTC)
ge profile icemaker problem (Refrigerator & Freezer Repair)
by lwilliams 7/2/2010 1:43:54 PM(UTC)
Weird Icemaker problem (Refrigerator & Freezer Repair)
by hoginokc 2/2/2010 3:51:36 PM(UTC)
by AustinBrooks 10/4/2009 1:15:23 PM(UTC)
