DCampeau
#1 Posted : Thursday, January 22, 2009 2:26:04 PM(UTC)
DCampeau
my question is this,
My Machine is not going into the agitation cycle , and the water level is not being controlled, however the basket will spin freely in the spin cycle, I just recently put a new motor belt on and everytjing there checks out fine, is this problem related to the timer switch.
Duane Campeau
Drags1998
#2 Posted : Thursday, January 22, 2009 3:22:32 PM(UTC)
Drags1998
The problem IS the water level selector switch!!!!!
DCampeau
#3 Posted : Thursday, January 22, 2009 4:43:17 PM(UTC)
DCampeau
Draggs1998
would this cause the agitator not to operate correctly ?
Drags1998
#4 Posted : Friday, January 23, 2009 3:41:06 PM(UTC)
Drags1998
Yes, It sure will!!!! The motor will not get power until the water level switch is satisfied, and you said the water level was NOT being controled. Lift the top of the washer and follow the 1/4" tube from the bottom of the tub up to the pressure switch. check the tube carefully, if its OK, Replace the switch!!!:)
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
Recommended replacement for WP22001311 Maytag Washing Machine Unbalance lever (Washer Repair)
Belarus Guest 4/29/2023 12:17:37 PM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
