DCampeau
#1 Posted : Thursday, January 22, 2009 2:26:04 PM(UTC)
DCampeau
my question is this,
My Machine is not going into the agitation cycle , and the water level is not being controlled, however the basket will spin freely in the spin cycle, I just recently put a new motor belt on and everytjing there checks out fine, is this problem related to the timer switch.
Duane Campeau
Drags1998
#2 Posted : Thursday, January 22, 2009 3:22:32 PM(UTC)
Drags1998
The problem IS the water level selector switch!!!!!
DCampeau
#3 Posted : Thursday, January 22, 2009 4:43:17 PM(UTC)
DCampeau
Draggs1998
would this cause the agitator not to operate correctly ?
Drags1998
#4 Posted : Friday, January 23, 2009 3:41:06 PM(UTC)
Drags1998
Yes, It sure will!!!! The motor will not get power until the water level switch is satisfied, and you said the water level was NOT being controled. Lift the top of the washer and follow the 1/4" tube from the bottom of the tub up to the pressure switch. check the tube carefully, if its OK, Replace the switch!!!:)
frigidare ATFB6000FS0 washing machine (Washer Repair)
by booknails 1/2/2019 1:38:27 PM(UTC)
Washing Machine agitator works but only after manual start (Washer Repair)
by dag403 12/2/2018 2:44:57 PM(UTC)
Maytag A510 Washing Machine keeps washing (Washer Repair)
by CaptKirk 11/8/2018 4:05:09 AM(UTC)
Washing machine hot temperature (Washer Repair)
by Bikemanz 11/4/2018 11:02:19 AM(UTC)
How to fix washing machine (Washer Repair)
by JennJenn 9/6/2018 7:49:39 AM(UTC)
Maytag Washing Machine overheats during spin (Washer Repair)
by DaveCheck 4/21/2018 6:44:25 AM(UTC)
washing machine (Dishwasher Repair)
by ozarkhillbilly2 4/2/2018 9:34:46 PM(UTC)
Replacing a Drum Baffle/Lifter for Samsung Washing Machine (Washer Repair)
by srivatsa11 1/11/2018 6:16:18 PM(UTC)
washing machine won't refill on rinse cycle (Washer Repair)
by sportster72 9/7/2017 6:40:10 AM(UTC)
Washing machine won't agitate, will spin though (Washer Repair)
by Freddy76 7/17/2017 4:05:56 PM(UTC)
Amana washing machine trouble (Washer Repair)
by Freddy76 7/17/2017 2:47:07 PM(UTC)
GE Washing Machine Drips When Off (Washer Repair)
by kevin1boyd 5/7/2017 5:48:33 AM(UTC)
Washing Machine Slow Fill for Hot Water (Washer Repair)
by wildblue 3/5/2017 3:31:47 PM(UTC)
washing machine not draining properly (Washer Repair)
by Howard67 2/23/2017 9:20:15 AM(UTC)
Washing Machine Wont Agitate Or Spin (Washer Repair)
by SCOTT1946 1/23/2017 12:31:34 PM(UTC)
