I have replaced the heating element and the two thermostats. It still is not heating.
Thank you Jerry
Originally Posted by: Jerry Odenwelder  I have replaced the heating element and the two thermostats. It still is not heating.
Thank you Jerry I have replaced the heating element and two thermostats and my dryer will still not heat
Here is your parts breakdown Model LET8858DQ1Here is the wiring diagram https://www.servicematters.com/d...0Sheet%20-%203401725.pdfHave you checked that you have 240 volts at the receptacle. Sometimes you can loose half the line without actually tripping the breaker. Try turning the breaker off/on a couple times slowly. Depending 3hich side drops out the motor will run but you will have no heat. Have you checked the Thermal Cutout (see the wiring diagram). Item 9 in "SECTION 3". To check you could short the wires together and tape them up so they cannot short to anything. Then give the unit a try. Do not leave the unit like this as it is a safety device. If required replace it ASAP. If it is the Thermal Cutout give the interior a good cleaning including the blower wheel. Also clean and check your vent system |
THIS FORUM IS DEAD!!!!!!! |
