Jerry Odenwelder
#1 Posted : Monday, January 12, 2009 6:27:01 AM(UTC)
Jerry Odenwelder
I have replaced the heating element and the two thermostats. It still is not heating.
Thank you
Jerry
Jerry Odenwelder
#2 Posted : Monday, January 12, 2009 6:32:40 AM(UTC)
Jerry Odenwelder
Thank you
Jerry
I have replaced the heating element and two thermostats and my dryer will still not heat
#3 Posted : Monday, January 12, 2009 7:22:28 AM(UTC)
Here is your parts breakdown
Model LET8858DQ1
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203401725.pdf
Have you checked that you have 240 volts at the receptacle.
Sometimes you can loose half the line without actually tripping the breaker.
Try turning the breaker off/on a couple times slowly.
Depending 3hich side drops out the motor will run but you will have no heat.
Have you checked the Thermal Cutout (see the wiring diagram).
Item 9 in "SECTION 3".
To check you could short the wires together and tape them up so they cannot short to anything. Then give the unit a try.
Do not leave the unit like this as it is a safety device.
If required replace it ASAP.
If it is the Thermal Cutout give the interior a good cleaning including the blower wheel.
Also clean and check your vent system
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
