tinley
#1 Posted : Thursday, January 8, 2009 7:44:15 AM(UTC)
tinley
This Admiral gas range model#DF255677 (now owned by Maytag) will not light. The cooktop works but the oven will not heat. It does not appear to be the ignitor. My husband says there is power to the ignitor. Can you provide a wiring schematic so that I can determine what part(s) is needed? Or can you make a diagnosis based on the information I have provided
THANK YOU...we need to use our oven!
libertyappl
#2 Posted : Thursday, January 8, 2009 8:37:51 AM(UTC)
libertyappl
It is most likely the ignitor, ohm the ignitor iself. The ignitor should ohm etween 3 & 3.5. If it doesn't replace the ignitor.
Nat
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Oven will not light (Oven Repair (including Ranges and Cooktops))
by easymoney12 9/18/2012 3:49:06 PM(UTC)
by gypsyqueen 5/24/2012 8:50:45 AM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
by ACummings 3/27/2012 1:51:01 PM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
by mikenpd133 10/6/2011 6:30:33 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by jdiddle 10/1/2010 4:38:38 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
