HAD A QUIET ARTNER II replaced control panel then thermal fuse got it up and running using reset keys now getting continuous blinking rinse only light what do I do! Spent major money on new board and fuse still no luck but for one half cycle.
Originally Posted by: kingmarkyd ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) HAD A QUIET ARTNER II replaced control panel then thermal fuse got it up and running using reset keys now getting continuous blinking rinse only light what do I do! Spent major money on new board and fuse still no luck but for one half cycle. Kingmarky, You most likely have(had) a or several bad keypad(s). ERROR MESSAGES
STUCK KEY:
If the control detects that a key is stuck in the depressed position, dishwasher operation will be suspended and the control will flash the light for that key until the condition is corrected. If a key without a light is stuck/shorted or multiple keys are stuck/shorted, the control will flash the Rinse cycle key light.
RAPID ADVANCE SERVICE FEATURE AND DIAGNOSTICS CYCLES
Pressing the following option keys in the sequence shown will either start the Diagnostics Cycle or turn on the Rapid Advance feature for customer selectable cycles:
HI TEMP WASH → AIR DRY → HI TEMP WASH → AIR DRY - or - HI TEMP SCRUB/SCOUR → AIR DRY → HI TEMP SCRUB/SCOUR → AIR DRY If the above key sequence is entered with the dishwasher in Standby, the Diagnostics Cycle is started. The operator can advance the cycle, interval by interval, by pressing the Pots & Pans or Anti-Bacteria key. You could also try, disconnecting the touchpad ribbon, from the new control board, thoroughly clean the insertion end of the ribbon with alcohol, re insert the ribbon, properly and tightly, and try again, after you reset the control board.
Good Luck, :) :) :)
