wayner451
#1 Posted : Monday, February 28, 2011 5:47:27 PM(UTC)
wayner451
I'm about to order a agitator kit and a motor coupling as these are broken. When I try to spin the tub by hand there is a decent amount of drag encountered. It takes some effort to spin it. Is this normal? I am concerened that I may have an additional problem. These parts are inexpensive but it's the unknown that I'm worried about. Thanks for any help on this..
Joe / APP Team
#2 Posted : Tuesday, March 1, 2011 11:32:40 AM(UTC)
Joe / APP Team
Wayne,
Based on your post, at this present time,
I presume, the upper "auger" part of the agitator can be moved in both directions,(it should only move counterclockwise) but the bottom is stationary(damaged agitator dogs).
To manually turn the spin basket, Yes, there is some resistance and does take some effort to turn, sounds normal.
The motor coupler assembly, drives the gearcase and clutch, to make the washer agitate and spin, if it is damaged , weak, or broken, there is no mechanical operation in the gearcase, and nothing moves.
I think you've got everything coverred, with the parts you've orderred.
(when you replace the new motor coupler, you'll most likely need a deep set socket and small hammer to tap it onto the motor and gearcase shafts, it's been redesigned and is a very tight fit, even after you clean off the shafts.
Good Luck,
Let us know how things go, we'd appreciate it.
Thanks,
wayner451
#3 Posted : Thursday, March 3, 2011 5:56:29 PM(UTC)
wayner451
Installed the ordered parts and it's working great! Thanks so much to you Joe and the great team at Appliance Parts Pros. No more fumbling around on the net...you guys are the one stop shop.
Wayne
Joe / APP Team
#4 Posted : Friday, March 4, 2011 5:49:32 AM(UTC)
Joe / APP Team
Wayne
Wayne,
We're Happy that your Happy !!!!
It was our pleasure to help you out.
Good Luck,
:D :D :D
Kenmore 110.22332510 not agitating or spinning. Tub low. (Washer Repair)
by herman_the_german2 5/2/2020 11:52:06 AM(UTC)
GE Washer Not Agitating or Spinning (Washer Repair)
by Gator84 8/17/2015 4:34:56 PM(UTC)
Kenmore Elite not agitating or spinning and obnoxiously noisy about it too! (Washer Repair)
by Melody Lee 1/5/2015 6:53:05 PM(UTC)
Inglis by Whirlpool Not Agitating or Spinning (Washer Repair)
by daetinuviel 2/1/2014 3:46:01 PM(UTC)
GE Front Load Washer Not Agitating or Spinning (Washer Repair)
by mghump 12/16/2013 6:13:15 AM(UTC)
by KerriH 7/19/2013 9:06:57 AM(UTC)
Kenmore 80 Series not agitating or spinning (Washer Repair)
by alane720 1/22/2013 8:15:15 AM(UTC)
Washer not agitating or spinning help please (Washer Repair)
by oxtart 9/10/2012 6:54:23 AM(UTC)
GE Front Loader-motor runs but not agitating or spinning (Washer Repair)
by lilkel37 4/19/2012 1:29:08 PM(UTC)
Fridigaire Washer not agitating or spinning (Washer Repair)
by Stoowey31 9/14/2011 5:07:29 PM(UTC)
GE front load washer not agitating or spinning (Washer Repair)
by randufull 7/11/2011 3:24:28 AM(UTC)
Not agitating or spinning (Washer Repair)
by darkwing.50 1/5/2011 6:16:32 AM(UTC)
Kennmore 80 Series not agitating or spinning (Washer Repair)
by Bec Bec 12/30/2008 5:56:45 PM(UTC)
