ddavis263
#1 Posted : 14 years ago
ddavis263
Turn the thermostat off and damper door closes and pump shuts off. If i turn it on, just barely, and the damper door opens and motor turns on. I can feel the cold air coming in at the damper and i can feel it shut off so, i assume, the door is opperating correctly.
Could it be the fresh food thermostat that has died? And how do you get the covers off to get to the thermostates and the damper? i took off every screw 1/4" and phillips i could see and it still didn't want to come out. What gives?
#2 Posted : 14 years ago
Cannot find any info for the given model number, please check it.
Are you sure it is not a H5ASB8 as per the below parts breakdown.
Replacement parts for FRIGIDAIRE FRS26H5ASB8 Frigidaire/refrigerator | AppliancePartsPros.com
This should help you open it up, see page 16.
http://frigidaireservicetips.com/pdfs/496_4.pdf
[COLOR="DarkRed"]Could it be the fresh food thermostat that has died?[/COLOR]
This thermostat controls the damper and you say that seems to be working.
I think I would check the freezer temperature. It should be 0 to 5 degrees F.
If it is too cold and/or the compressor is not cycling then perhaps it is the freezer thermostat that is the problem.
ddavis263
#3 Posted : 14 years ago
ddavis263
No i'm not sure about the model #. It woouldn't be the first time i have copied the wrong numbers down. Getting old sucks. I found the same issue when i tried to plug inthe model number and have been using the same one you suggested.
Thanks for the tip on getting access to the darn controls. I didn't want to break something and compound my problem.
I'm of the same opinion as you about the fresh food control. But let me ask you something, i did notice she has the freeezer stuffed with food, could poor circulation have something to do with her problem?
#4 Posted : 14 years ago
[COLOR="DarkRed"]i did notice she has the freeezer stuffed with food, could poor circulation have something to do with her problem?[/COLOR]
I would just be guessing.
I would have thought that poor circulation would have cause too high ot a temperature in the fresh food not too low.
refrigerator freezing everything (Refrigerator & Freezer Repair)
by terryo19652009 11 years ago
Kenmore Coldspot Side by Side - Refrigerator freezing everything (Refrigerator & Freezer Repair)
by nickk678 13 years ago
Side-by-side refrigerator freezing everything (Refrigerator & Freezer Repair)
by wjcwalker 15 years ago
GE refrigerator freezing everything (Refrigerator & Freezer Repair)
by AnneM 16 years ago
by dbares1 17 years ago
