Everything in our refrigerator is freezing. Control setting is turned down to zero. Freezer side is functioning fine. This unit is in our garage - would that environment be part of the problem?
Do you have a regular mechanical cold control, the type that turns the compressor off.
Hi dbares1
In order to provide the most accurate advise I need the complete model number of you fridge.
