Mrkis
#1 Posted : Sunday, January 30, 2011 9:09:01 AM(UTC)
Mrkis
My GE washer is leaking from the top left of the front drum. leaking when unit is off after a load has been run. I emptied the screen behind the front door but its still leaking anf filling up the base drawers. Seems like it always leaking. Any help would be great!!
Joe
sidfink43
#2 Posted : Monday, January 31, 2011 5:12:02 PM(UTC)
sidfink43
It sounds like the problem is with the valve assembly and the water in take line that come from the faucet to the valve assembly through the detergent drawer and into the machine.
Check out that route and you should find your problem.
Also, clean out the pump and drain system, that can also be an issue.
Leaking Washer (Washer Repair)
by midget73 7/27/2014 3:27:00 PM(UTC)
by broonsparrow 11/30/2013 10:15:30 AM(UTC)
Leaking washer need advice (Washer Repair)
by GE Nightmare 10/5/2013 1:54:30 PM(UTC)
leaking washer (Washer Repair)
by ashkdaot 6/25/2013 6:23:18 PM(UTC)
by Jags 12/22/2012 8:37:52 AM(UTC)
by martha725 8/3/2012 2:11:37 PM(UTC)
leaking washer and won't drain (Dishwasher Repair)
by colt 11/6/2011 2:15:14 PM(UTC)
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 11/5/2011 6:14:56 PM(UTC)
Leaking washer (Washer Repair)
by Crowell 9/6/2011 9:11:30 AM(UTC)
leaking washer during filling (Washer Repair)
by bonnetinsurance 8/10/2011 7:44:44 AM(UTC)
by 03svrider 6/9/2011 10:48:37 AM(UTC)
by rcarroll7703 6/1/2011 7:50:27 AM(UTC)
by donandlynn 5/7/2011 7:32:41 AM(UTC)
by Clueless101 12/27/2010 12:33:13 PM(UTC)
by wirenutt2 12/6/2010 9:44:26 PM(UTC)
