tinman14
#1 Posted : 14 years ago
tinman14
Electric Dryer Starts And Turns Slowly. If Clothes Are Addded, The Dryer Will Not Turn, Or Turn Slowly And At Uneven Speed. I Recently Replaced The Heating Element, Idler Assembly, Front Seal , Belt Amd Thermal Coupler. Help Me Finish This Job...please
#2 Posted : 14 years ago
Was this the original problem or has this just started since you worked on the unit.
Try turning the drum in the correct direction by hand.
Should turn fairly easily.
You may want to try this on a couple other dryers to get a feel for it.
If it is hard to turn then it is probably the rear support bearing or the front drum support.
kayakcrzy
#3 Posted : 14 years ago
kayakcrzy
4:10 in the morning.....Denman you are getting up to early!! Yikes!!! Denman how about sending that how to put the belt on site. Sounds like the bellt is slipping, or the idler pully might be the issue. Check and see if you put the idler pully spring in the right place. Tom ApplianceEducator.com
#4 Posted : 14 years ago
Here are the belt sites as it may well be a slipping belt.
http://forum.appliancepartspros...dryer-belt-diagrams.html
Note the the ribbing on the belts. They show it going across the belt not along it but this is just so you know which is the ribbed side.
http://www.applianceaid.com/images/belt-config.JPG
Dryer Repair Again and Again (Dryer Repair)
by Guest 3 years ago
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 3 years ago
Dryer repairs (Dryer Repair)
by P3FE 3 years ago
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 5 years ago
Dryer Repair Issue (Dryer Repair)
by jdharrin 5 years ago
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 7 years ago
Dryer repair Help! (Dryer Repair)
by Hah45 7 years ago
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 9 years ago
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 9 years ago
Dryer Repair (Dryer Repair)
by sotomargie 9 years ago
Dryer repair (Dryer Repair)
by dchurch 9 years ago
by jaybick 10 years ago
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10 years ago
by Tom Campion 11 years ago
by kencorey281@gmail.com 11 years ago
