tinman14
#1 Posted : Tuesday, January 18, 2011 4:28:12 PM(UTC)
tinman14
Electric Dryer Starts And Turns Slowly. If Clothes Are Addded, The Dryer Will Not Turn, Or Turn Slowly And At Uneven Speed. I Recently Replaced The Heating Element, Idler Assembly, Front Seal , Belt Amd Thermal Coupler. Help Me Finish This Job...please
#2 Posted : Wednesday, January 19, 2011 1:10:02 AM(UTC)
Was this the original problem or has this just started since you worked on the unit.
Try turning the drum in the correct direction by hand.
Should turn fairly easily.
You may want to try this on a couple other dryers to get a feel for it.
If it is hard to turn then it is probably the rear support bearing or the front drum support.
kayakcrzy
#3 Posted : Wednesday, January 19, 2011 3:16:21 AM(UTC)
kayakcrzy
4:10 in the morning.....Denman you are getting up to early!! Yikes!!! Denman how about sending that how to put the belt on site. Sounds like the bellt is slipping, or the idler pully might be the issue. Check and see if you put the idler pully spring in the right place. Tom ApplianceEducator.com
#4 Posted : Wednesday, January 19, 2011 3:32:59 AM(UTC)
Here are the belt sites as it may well be a slipping belt.
http://forum.appliancepartspros...dryer-belt-diagrams.html
Note the the ribbing on the belts. They show it going across the belt not along it but this is just so you know which is the ribbed side.
http://www.applianceaid.com/images/belt-config.JPG
Guest (4)
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
