jwes
#1 Posted : Saturday, November 29, 2008 4:55:58 AM(UTC)
jwes
My Frigidaire washer model FWX223LBS7 won't spin. Everything else seems to be working okay. It fills, agitates and drains, but won't spin. It smells hot after a while when on the "spin" cycle. The lid switch seems to be working.
cpatterson
#2 Posted : Saturday, November 29, 2008 8:15:22 AM(UTC)
cpatterson
youre problom could only be the belt which only cost about $6.00 or the motor.
jwes
#3 Posted : Saturday, November 29, 2008 9:28:35 AM(UTC)
jwes
It is possible that it could be the belt, but I don't think so.. I looked at the machine again this morning & found that the belt is slipping on the motor pulley. That may be due to the fact that the drum will not spin at all. I tried to spin it by hand from the top, through the washer door, & it wouldn't budge. I then took the belt off, set the machine on "spin", and then tried to turn the transmission pulley by hand. Again, it wouldn't budge either. That leads me to believe that the transmission is locked up. I am assuming , of course, that I should be able to spin the drum by hand.
Frigidaire Washer Won't Spin after replacing drive belt (Washer Repair)
by Shindigit 5/4/2013 10:54:15 AM(UTC)
frigidaire washer won't spin cloths dry (Washer Repair)
by MrVix 1/29/2012 12:17:20 PM(UTC)
Frigidaire Washer won't spin (Washer Repair)
by csnow 12/16/2011 8:06:42 AM(UTC)
by John Mascarena 12/12/2011 12:05:41 PM(UTC)
Frigidaire washer won't spin (Washer Repair)
by maggiemc 11/29/2011 6:39:13 PM(UTC)
Frigidaire Washer won't spin or drain (Washer Repair)
by jcutillo 8/21/2011 10:15:07 AM(UTC)
Frigidaire washer won't spin fast (Washer Repair)
by wiredmonkey 7/6/2011 9:35:37 AM(UTC)
Frigidaire washer won't spin won't drain (Washer Repair)
by janterry 2/16/2011 6:34:44 AM(UTC)
frigidaire washer won't spin out!! (Washer Repair)
by highwaystar 1/27/2010 7:56:47 PM(UTC)
Frigidaire Washer Won't Spin Out (Washer Repair)
by noley99 11/22/2009 7:13:08 AM(UTC)
by stein1960 11/21/2009 12:44:53 PM(UTC)
by maclean 7/28/2009 11:08:42 AM(UTC)
Stackable Kenmore/Frigidaire washer won't spin (Washer Repair)
by sidevinder 5/4/2009 9:48:51 AM(UTC)
by texican 3/5/2009 5:43:41 AM(UTC)
by cdiscolo 12/25/2007 6:39:58 AM(UTC)
