The dryer has power to it but will not start. When i push the start button it beeps 3 times and that is it. I replace the thermal fuse, but that did not solve the problem. What could cause this and how can I fix it?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Here are your parts
Here is a manual https://secured.whirlpoo...61e709/$FILE/8178559.pdfFirst try unplugging the unit for 5 minutes or so, to see if it will reset. If this does nothing try running the diagnostics. Could be the door switch so try activating it manually. I ran the diagnostics, it shows 0E on the display with all the lights lit up. I could not find that code in the manual. What does this mean? Thanks for your help.
I do not know what it means. I did some searching and still could not come up with any info that specified what exactly this is supposed to mean. Or even if it is a fault.
They do mention it on Page 6-15 in the manual but no real info on it.
Perhaps you may want to open a new post asking this question, hopefully someone else will be able to shed some light on this. |
