jmp1721
#1 Posted : Friday, December 17, 2010 5:42:14 PM(UTC)
jmp1721
The dryer has power to it but will not start. When i push the start button it beeps 3 times and that is it. I replace the thermal fuse, but that did not solve the problem. What could cause this and how can I fix it?
#2 Posted : Saturday, December 18, 2010 3:16:38 AM(UTC)
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
First try unplugging the unit for 5 minutes or so, to see if it will reset.
If this does nothing try running the diagnostics.
Could be the door switch so try activating it manually.
jmp1721
#3 Posted : Sunday, December 19, 2010 7:52:17 AM(UTC)
jmp1721
Originally Posted by: denman Go to Quoted Post
Here is a manual
https://secured.whirlpoo...61e709/$FILE/8178559.pdf
I ran the diagnostics, it shows 0E on the display with all the lights lit up. I could not find that code in the manual. What does this mean? Thanks for your help.
#4 Posted : Monday, December 20, 2010 5:20:09 AM(UTC)
I do not know what it means.
I did some searching and still could not come up with any info that specified what exactly this is supposed to mean. Or even if it is a fault.
They do mention it on Page 6-15 in the manual but no real info on it.
Perhaps you may want to open a new post asking this question, hopefully someone else will be able to shed some light on this.
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
maytag legacy dryer wont start (Dryer Repair)
by kennypkay 11/15/2015 2:02:45 PM(UTC)
Admiral Dryer wont start (Dryer Repair)
by chargitt 8/24/2015 1:25:34 PM(UTC)
kenmore dryer wont start (Dryer Repair)
by coindog1 7/26/2015 12:33:16 PM(UTC)
by antoine123 6/10/2015 5:23:52 PM(UTC)
dryer contol lock is locked -dryer wont start (Dryer Repair)
by k62254 5/29/2015 1:10:18 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Whirlpool dryer wont start (Dryer Repair)
by laundry1 1/20/2015 11:46:37 AM(UTC)
dryer wont start (Washer Repair)
by rangerleader63@gmail.com 9/4/2014 7:56:01 AM(UTC)
by mich01 9/1/2014 4:17:03 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
by cnrimgr1 2/17/2014 12:27:23 PM(UTC)
