:confused: when going into the spin cycle the washer will not spin. i have to spin by hand as fast as i can to kick start it. now it just won't spin. also the tube moves around alot. you can move it side ways and almost see down the inside.
Originally Posted by: babassmaster  ...the tube moves around alot. you can move it side ways and almost see down the inside... Remove the front panel and check the tub dampening straps (#370 on the break down diagram). Regarding the spin problem the first failure suspect is the motor and I would recommend to replace the belt too. - The part number for the motor & clutch assembly is AP3160670 - The part number for the belt is AP2044592 Here are the break down diagrams for the GE washer Model S3200Y0WWGene.
can I tighten the dampening straps by turning them evenly?
As far as I know they are not adjustable.
