babassmaster
#1 Posted : Wednesday, November 5, 2008 5:35:08 PM(UTC)
babassmaster
:confused: when going into the spin cycle the washer will not spin. i have to spin by hand as fast as i can to kick start it. now it just won't spin. also the tube moves around alot. you can move it side ways and almost see down the inside.
#2 Posted : Thursday, November 6, 2008 1:17:38 PM(UTC)
Originally Posted by: babassmaster Go to Quoted Post
...the tube moves around alot. you can move it side ways and almost see down the inside...
Remove the front panel and check the tub dampening straps (#370 on the break down diagram).
Regarding the spin problem the first failure suspect is the motor and I would recommend to replace the belt too.
- The part number for the motor & clutch assembly is AP3160670
- The part number for the belt is AP2044592
Here are the break down diagrams for the GE washer Model S3200Y0WW
babassmaster
#3 Posted : Thursday, November 6, 2008 8:30:16 PM(UTC)
babassmaster
can I tighten the dampening straps by turning them evenly?
#4 Posted : Thursday, November 6, 2008 9:50:15 PM(UTC)
As far as I know they are not adjustable.
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
by howard6168 7/5/2015 5:47:41 AM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
