Any help would be appreciated. Is it difficult to install a thermostat in a frigidaire affinity dryer?
What is the complete model number of the dryer?
Which thermostat would you like to replace?
What is wrong with the dryer?
Model number is AEQ6000ES2. The dryer is running extremely hot, cleaned all of the venting inside and out. Was told that the thermostat is most likely bad. Was told that the thermostat is part number AP2131477. Thanks for any help.
