tarandmars
#1 Posted : Wednesday, November 10, 2010 7:20:21 AM(UTC)
tarandmars
Any help would be appreciated. Is it difficult to install a thermostat in a frigidaire affinity dryer?
#2 Posted : Wednesday, November 10, 2010 10:16:15 AM(UTC)
What is the complete model number of the dryer?
Which thermostat would you like to replace?
What is wrong with the dryer?
tarandmars
#3 Posted : Thursday, November 11, 2010 7:13:41 AM(UTC)
tarandmars
Model number is AEQ6000ES2. The dryer is running extremely hot, cleaned all of the venting inside and out. Was told that the thermostat is most likely bad. Was told that the thermostat is part number AP2131477. Thanks for any help.
#4 Posted : Monday, November 15, 2010 5:31:56 PM(UTC)
Remove the top panel by removing the two screws in the rear and sliding the top back 1/2" and lift the top off.
Disconnect the two wires and remove the two screws holding the thermostat to the heating element assembly.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE AEQ6000ES2 Frigidaire/dryer | AppliancePartsPros.com
Samsung Dryer thermostat/thermistor quick question (Dryer Repair)
by jhuck 3/6/2014 7:22:46 PM(UTC)
Dryer Thermostat? (Dryer Repair)
by SynchHD 11/9/2013 1:23:11 PM(UTC)
Maytag Dryer Thermostat Issue (Dryer Repair)
by buddha131 4/19/2013 10:55:57 AM(UTC)
gibson dryer thermostat position (Dryer Repair)
by handyman59 5/31/2011 5:24:53 AM(UTC)
checking dryer thermostats (Dryer Repair)
by shields 3/28/2011 3:37:54 PM(UTC)
dryer thermostat (Dryer Repair)
by ironmanpj04 3/10/2011 6:28:41 AM(UTC)
GE Dryer thermostat help (Dryer Repair)
by bay-fisher@hotmail.com 11/1/2009 11:38:15 AM(UTC)
Dryer Thermostat Keeps Failing (Dryer Repair)
by Jeff_S 10/4/2009 7:52:08 AM(UTC)
