sting66ray
#1 Posted : Thursday, October 30, 2008 6:06:04 AM(UTC)
sting66ray
The "timer switch will not advance during automatic cycles, but will advance during timed dry. However, the timed dry cycle will not dry clothes in 90 minutes, there is progress toward drying , but clothes are damp. The ignitor glows and the burner lights, but i can only watch it for so long with front panel off. Help! thank you!!!!
libertyappl
#2 Posted : Thursday, October 30, 2008 6:16:24 AM(UTC)
libertyappl
For starters I would check the entire system for a blockage in the exhaust system. From the lint trap all the way outside.
Nat
sting66ray
#3 Posted : Thursday, October 30, 2008 6:50:00 AM(UTC)
sting66ray
Already check for blockage, and removed lint trap ductwork and vacuumed out and vacuumed burner area and cleaned flame sensor. When it runs it has good strong exhaust outside the house.
thanks
dave
magician59
#4 Posted : Friday, October 31, 2008 8:54:42 AM(UTC)
magician59
Could be the dryness sensor; then again, maybe it's trying to tell you there's something wrong with your washer's spin cycle.
sting66ray
#5 Posted : Friday, October 31, 2008 11:11:25 AM(UTC)
sting66ray
There isn't a dryness sensor on the schematic, and the clothes are as no damper than usual out of the washer. lol
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
by Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
