quester
#1 Posted : Wednesday, October 22, 2008 9:12:55 PM(UTC)
quester
Our oven does not work properly. I have checked the wiring and the elements. I can see no obvious places to suspect in the wiring, and I checked the elements with a voltmeter both for continuity and for shorting from the wire to the outer shell. Each element read about 20-22 ohms on a 200 ohm scale. I ordered and received a replacement control but find that it does not work. Since I waited too long to install it, Sears will not allow me to return it..Anyone have any other ideas??
#2 Posted : Thursday, October 23, 2008 7:02:49 PM(UTC)
Originally Posted by: quester Go to Quoted Post
...Our oven does not work properly...
Can you be more specific on the problem, please?
GE Oven Control board locking after starting oven. Model # CGS985SETASS (Oven Repair (including Ranges and Cooktops))
by Mike I 1/15/2024 10:55:45 PM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
GE Gas Oven Control panel blank (Oven Repair (including Ranges and Cooktops))
by sjohnson1161 3/17/2021 6:23:41 PM(UTC)
GE Electric double oven control panel part number (Oven Repair (including Ranges and Cooktops))
by Steveg297 6/20/2020 6:48:16 AM(UTC)
GE range JB645DK4BB, oven controls do not work (Oven Repair (including Ranges and Cooktops))
by jpmriley 2/24/2020 8:45:36 AM(UTC)
My double oven control board headaches (Oven Repair (including Ranges and Cooktops))
by Gunner41 12/9/2019 7:16:45 AM(UTC)
Oven Controls of Kitchenaid (Oven Repair (including Ranges and Cooktops))
by dballard1956 11/20/2018 4:14:02 PM(UTC)
How to remove Superba Oven Control Panel (Oven Repair (including Ranges and Cooktops))
by gofastr 4/5/2018 7:20:54 PM(UTC)
Stovetop is working, but the oven and oven controls are not (Oven Repair (including Ranges and Cooktops))
by EgorFed 1/7/2018 4:33:15 PM(UTC)
Replaced Oven Control Board- Controls still dont work (Oven Repair (including Ranges and Cooktops))
by chuckwagon00 12/10/2017 3:48:56 PM(UTC)
GE Oven Control Board (Oven Repair (including Ranges and Cooktops))
by BillDiesel 12/5/2017 7:36:41 AM(UTC)
Oven control board? (Oven Repair (including Ranges and Cooktops))
by denverdave 4/21/2017 8:44:54 AM(UTC)
Ikea Whirlpool IBS550PWW00 In wall oven Control Thermal Fuse?? (Oven Repair (including Ranges and Cooktops))
by teamlouish 3/29/2017 3:54:29 PM(UTC)
Clock & Oven controls not working (Oven Repair (including Ranges and Cooktops))
by wfcoleman 1/2/2017 2:51:37 PM(UTC)
oven control panel not working (Oven Repair (including Ranges and Cooktops))
by nocookintoday 1/26/2016 8:04:15 PM(UTC)
