Joined: 12/9/2019(UTC) Posts: 0  Location: San Jose, Ca
Good morning all,
Im in need of some of your wisdom. I have a Maytag double oven (MEW6627DDS). Last weekend we had a power outage. My oven's display did not come back on when the power was returned. I noticed the light bulbs didn't come on as well. I flipped the breakers and still it didn't come back on. I flipped ALL the breakers and sat for about 5 min and still nothing. Of course I wont let it beat me (not yet) I pulled the oven out of the wall and got to the control board. Now I tested power coming in to the terminal block (three stud block). outside probes read 240 then Right and center probes 120 then Left and center 120. I tested it the control board connector (still plugged in) and read 240. I'm not sure where to go to test if the board is bad. I was looking for a thermal fuse but haven't found one yet... Thanks for any help.
