Evonne
#1 Posted : Wednesday, October 22, 2008 12:52:24 PM(UTC)
Evonne
Our washing machine will not fill with water. Once and a while it will but not consistently. Also when it does fill during the wash cycle it won't in the rinse cycle. We checked the hose and it is clear. We also replaced the water level switch part #3366848. It worked right through one full cycle and now will not work again. Any further suggestions would be helpful
libertyappl
#2 Posted : Wednesday, October 22, 2008 12:54:11 PM(UTC)
libertyappl
Evonne,
Did you check the fill tube to see if it has any water or pin holes in it?
You may also want to check the valve screens to make sure they don't have any debris.
Do you wash primarily in cold?
Nat
