Tcon
#1 Posted : Sunday, October 17, 2010 6:22:21 AM(UTC)
Tcon
Dryer suddenly stopped heating. Everything else works fine.
#2 Posted : Sunday, October 17, 2010 11:24:57 AM(UTC)
Replacement parts for WHIRLPOOL GEQ9800LG1 27"electric Dryer | AppliancePartsPros.com
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Check the thermal cut-off (fuse) (Item 47 in Section 3)
Should be 0 ohms.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
kayakcrzy
#3 Posted : Monday, October 18, 2010 3:11:02 PM(UTC)
kayakcrzy
It will most likely be the heater or the thermal fuse!! Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
Kenmore Dryer stopped heating. (Dryer Repair)
by willow5000 9/24/2014 1:48:01 PM(UTC)
Whirlpool Dryer stopped heating (Dryer Repair)
by jambla 8/19/2014 12:27:22 PM(UTC)
by jrnutpaul 9/20/2013 8:31:58 AM(UTC)
dryer stopped heating and runs non stop (Dryer Repair)
by jescousa 2/26/2013 8:30:05 AM(UTC)
Dryer Stopped Heating Up (Dryer Repair)
by rrblk 10/8/2011 4:12:13 PM(UTC)
Whirlpool Estate Dryer Stopped Heating (Dryer Repair)
by kimyoung 5/16/2011 8:58:46 AM(UTC)
GE dryer stopped heating but dryer still works (Dryer Repair)
by picker1 4/6/2011 6:53:41 AM(UTC)
Help...my dryer stopped heating (Dryer Repair)
by BDGD 12/3/2010 12:47:30 PM(UTC)
by jstayoung1 6/10/2010 12:37:53 AM(UTC)
by jstayoung1 6/10/2010 12:21:32 AM(UTC)
by atciskanik 3/3/2010 4:32:59 AM(UTC)
whirlpool gas dryer stopped heating what could be the problem (Dryer Repair)
by Lacey14 1/18/2010 5:39:07 AM(UTC)
Admiral Dryer Stopped Heating. Why? (Dryer Repair)
by kelso1 9/5/2009 7:33:29 AM(UTC)
GE Elec stackable dryer stopped heating (Dryer Repair)
by arbiggs 4/21/2009 11:23:47 AM(UTC)
