Freezer and Frig maintaining temps but not set temps.
Freezer = 22 degrees Refrig = 44 degrees
I opened up the back, everthing is clean, fan runs and compressor is working. There is no ice build up any where.
I have both settings set at recommended settings, and everything was working until I woke up this morning and everything in freezer was thawed. I am wondering if I should order a Mother board or am I barking up the wrong tree.
Originally Posted by: rkrueger  1/ ...I opened up the back, everthing is clean, fan runs and compressor is working. There is no ice build up any where...
2/ ...everything was working until I woke up this morning and everything in freezer was thawed... 1/ When did you do it? 2/ Did you check the compressor and fans at that time? Here are the breakdown diagrams and Replacement parts for General Electric PSS23MSTESS Refrigerator | AppliancePartsPros.comGene.
