Louis Tisovec
#1 Posted : Tuesday, September 21, 2010 12:42:19 PM(UTC)
Louis Tisovec
The power is on but the washer control panel stays at 28 minutes and the stop/cancel display does not clear the panel. I installed a new Electronis Control board I purchased from you, but the problem remains. What part should I order next:confused:
sidfink43
#2 Posted : Friday, September 24, 2010 9:01:20 AM(UTC)
sidfink43
Well, sorry that did not fix things, but see if you can put the machine in diagnostic mode, which you should be able to do since your main board is ok.
Here is the tech sheet that will tell you how to do it.
http://www.servicematters.com/d...0Sheet%20-%208522206.pdf
Louis Tisovec
#3 Posted : Tuesday, November 16, 2010 8:56:45 AM(UTC)
Louis Tisovec
I can not view the tech sheet you sent me on 9/24/2010 so that I can put the Whirlpool washer GVW9959KQ0 in diagnostic mode. It was a great help. Can you please email it again to zzdoc@msn.com, thanks
sidfink43
#4 Posted : Tuesday, November 16, 2010 3:58:00 PM(UTC)
sidfink43
The reason you cannot get that sheet is that Whirlpool has eliminated access to their tech library unless you are willing to pay big bucks.
See if a tech sheet is inside the console, and if not, call Whirlpool and get them to send you one and while you are at it, register a strong complaint that they will not make tech info available to you so you can fix your machine.
DMT400RHS/XAA stopped working / no lights / no response (Dishwasher Repair)
by TN_Snoopy 5/23/2022 5:21:09 AM(UTC)
Keypad dead/no response (Dishwasher Repair)
by mpetersrx7 4/20/2014 5:13:04 PM(UTC)
No response (Dishwasher Repair)
by benmcgraw 4/3/2014 9:29:15 AM(UTC)
Whirlpool dishwasher 1 1/2 years old no response from control panel (Oven Repair (including Ranges and Cooktops))
by StanF 11/15/2012 4:13:40 PM(UTC)
Quiet Partner 3 - no lights no response (Dishwasher Repair)
by kbrebs 10/24/2012 5:03:20 PM(UTC)
no response (Refrigerator & Freezer Repair)
by snyderrita 8/10/2012 1:29:07 PM(UTC)
GE microwave no response (Microwave Repair)
by ddavis263 3/15/2012 6:47:27 AM(UTC)
No response to touch pad controls (Oven Repair (including Ranges and Cooktops))
by oknoproblem 6/24/2011 10:41:10 AM(UTC)
No response-Whirlpool (Refrigerator & Freezer Repair)
by jsmi 6/8/2011 6:34:56 AM(UTC)
no ice, no response to jumper (Refrigerator & Freezer Repair)
by paulmstew 4/16/2011 5:06:26 PM(UTC)
No Response (Dishwasher Repair)
by stinger66 8/27/2010 12:53:03 PM(UTC)
Blank display no response from keypad (Oven Repair (including Ranges and Cooktops))
by BTLAMAR 11/16/2009 2:52:13 AM(UTC)
Power on, no response from control panel for double oven (Oven Repair (including Ranges and Cooktops))
by akers5va 6/1/2008 12:01:30 PM(UTC)
Pop, Sparks, No Response (Microwave Repair)
by novice skills 8/13/2007 4:46:19 PM(UTC)
