The power is on but the washer control panel stays at 28 minutes and the stop/cancel display does not clear the panel. I installed a new Electronis Control board I purchased from you, but the problem remains. What part should I order next:confused:
Originally Posted by: sidfink43  I can not view the tech sheet you sent me on 9/24/2010 so that I can put the Whirlpool washer GVW9959KQ0 in diagnostic mode. It was a great help. Can you please email it again to zzdoc@msn.com, thanks
The reason you cannot get that sheet is that Whirlpool has eliminated access to their tech library unless you are willing to pay big bucks.
See if a tech sheet is inside the console, and if not, call Whirlpool and get them to send you one and while you are at it, register a strong complaint that they will not make tech info available to you so you can fix your machine.
