jct1953
#1 Posted : Wednesday, September 24, 2008 4:41:11 PM(UTC)
jct1953
I Just Installed A New Time Control In This Unit And It Will Not Turn The Dryer Off ( This Is The Same Issue I Had With The Original Timer And The Reason I Replaced It ).... The Timer Does Not Move, I Set It For 10min Come Back In 20min And It Has Not Moved. Is There Something Else That Would Cause This To Happen??
libertyappl
#2 Posted : Wednesday, September 24, 2008 4:46:48 PM(UTC)
libertyappl
Does the dryer run and heat?
Check your door switch, if the door switch isn't functioning then you may get the same effect.
Nat
jct1953
#3 Posted : Wednesday, September 24, 2008 5:15:39 PM(UTC)
jct1953
The Dryer does run and heat... The timer just does not move to off position. Door switch appears to function OK; dryer will turn off if door is opened while running..
libertyappl
#4 Posted : Wednesday, September 24, 2008 6:15:50 PM(UTC)
libertyappl
Did you follow the wiring to the timer?
Nat
Ronald Windham
#5 Posted : Thursday, September 25, 2008 5:08:51 AM(UTC)
Ronald Windham
Nat
Good morning, Nat.
I have the same issue as JCT1953 with my Maytag Model MDE7400 AYW SN 19729588CL. I ordered and installed PN 33002803. Exactly same symptons--runs and heats, but the dial does not advance nor turn off the dryer. Door switch is operating.
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
