I Just Installed A New Time Control In This Unit And It Will Not Turn The Dryer Off ( This Is The Same Issue I Had With The Original Timer And The Reason I Replaced It ).... The Timer Does Not Move, I Set It For 10min Come Back In 20min And It Has Not Moved. Is There Something Else That Would Cause This To Happen??
Does the dryer run and heat? Check your door switch, if the door switch isn't functioning then you may get the same effect. Nat
The Dryer does run and heat... The timer just does not move to off position. Door switch appears to function OK; dryer will turn off if door is opened while running..
Did you follow the wiring to the timer? Nat
Originally Posted by: libertyappl  Did you follow the wiring to the timer? Nat Good morning, Nat. I have the same issue as JCT1953 with my Maytag Model MDE7400 AYW SN 19729588CL. I ordered and installed PN 33002803. Exactly same symptons--runs and heats, but the dial does not advance nor turn off the dryer. Door switch is operating.
