MBKENMORE
#1 Posted : Wednesday, September 8, 2010 10:00:42 AM(UTC)
MBKENMORE
I recently ordered part #4391960 which is the Heating element. I need to know if I also need to order the dryer thermal fuse. Dryer does everything besides heat.
Joe / APP Team
#2 Posted : Wednesday, September 8, 2010 11:47:58 AM(UTC)
Joe / APP Team
MB,
Did you have any heat problems before this occurred ?
If you had no heating problems, and you find that the element is broken and not shorted out, you will most likely not need a thermal fuse.
If you have a test meter or light you can check the fuse for a closed(infinite) circuit.
Good Luck,
Kenmore dryer not heating (Dryer Repair)
by jpdkrty 8/13/2016 3:50:00 PM(UTC)
Kenmore dryer not heating properly (Dryer Repair)
by yyzt4e 7/8/2015 4:58:45 PM(UTC)
Kenmore Dryer Not Heating After We Did Changed the Rear Drum Felt Seal (Dryer Repair)
by kytre 6/2/2015 7:25:49 PM(UTC)
Kenmore Dryer not heating (Dryer Repair)
by bkenner 3/23/2014 5:42:55 PM(UTC)
by Drichie 5/21/2013 3:29:30 PM(UTC)
Kenmore dryer not heating - next steps? (Dryer Repair)
by bangelus 12/6/2012 5:59:36 AM(UTC)
by murphy7513 7/4/2012 8:17:34 PM(UTC)
by PIO_ACA_CMY 1/5/2012 3:23:10 PM(UTC)
kenmore dryer not heating (Dryer Repair)
by bwoltanski 12/27/2011 9:01:29 AM(UTC)
by Dando 6/18/2011 12:45:41 PM(UTC)
by TexFordD 3/20/2011 10:15:14 AM(UTC)
by JaxMax 3/14/2011 9:11:16 AM(UTC)
by RepDry 9/23/2009 4:48:25 PM(UTC)
by lego1231 9/21/2009 8:18:43 AM(UTC)
Electric Kenmore Dryer not heating (Dryer Repair)
by morenojx 9/2/2009 7:32:58 AM(UTC)
