murphy7513
#1 Posted : Wednesday, July 4, 2012 8:17:34 PM(UTC)
murphy7513
My kenmore dryer is running but I am getting no heat. I am going to order the fuses and try to replace them first. However, I am not sure where they are loacted. Can you help with where they are located. Thanks
#2 Posted : Thursday, July 5, 2012 1:30:36 AM(UTC)
Replacement parts for Kenmore 11068722700 | AppliancePartsPros.com
If you go to the Sears parts site they have part breakdowns. Unfortunately they like to keep these in-house so they are not available at AppliancePartsPros. You want to look at the Bulkhead diagram at Sears, the fuses for heat are on the heater assembly (Item 47). See below the APP part. If you click on the picture a new page will open with info on this part.
Part number: AP3094224
No heat can have many causes.
The heater runs off of 240 so check power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK then unplug the unit and check the heating element.
They are usually 8 to 12 ohms.
If OK then check the thermal fuse on the heater assembly.
If blown get back tyo us as you have to look to see what caused it to blow.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
swant50
#3 Posted : Friday, July 6, 2012 1:21:59 PM(UTC)
swant50
after removing all hardware, the back will not come off,trying to replace thermostat
#4 Posted : Saturday, July 7, 2012 2:35:26 AM(UTC)
I believe you have to go in through the front.
The following should help.
Dryer Belt (Whirlpool made dryers, part #341241)-How To Replace - YouTube
Also the Sears parts site has actual parts breakdowns that may be useful.
Kenmore dryer not heating (Dryer Repair)
by jpdkrty 8/13/2016 3:50:00 PM(UTC)
Kenmore dryer not heating properly (Dryer Repair)
by yyzt4e 7/8/2015 4:58:45 PM(UTC)
Kenmore Dryer Not Heating After We Did Changed the Rear Drum Felt Seal (Dryer Repair)
by kytre 6/2/2015 7:25:49 PM(UTC)
Kenmore Dryer not heating (Dryer Repair)
by bkenner 3/23/2014 5:42:55 PM(UTC)
by Drichie 5/21/2013 3:29:30 PM(UTC)
Kenmore dryer not heating - next steps? (Dryer Repair)
by bangelus 12/6/2012 5:59:36 AM(UTC)
by PIO_ACA_CMY 1/5/2012 3:23:10 PM(UTC)
kenmore dryer not heating (Dryer Repair)
by bwoltanski 12/27/2011 9:01:29 AM(UTC)
by Dando 6/18/2011 12:45:41 PM(UTC)
by TexFordD 3/20/2011 10:15:14 AM(UTC)
by JaxMax 3/14/2011 9:11:16 AM(UTC)
by MBKENMORE 9/8/2010 10:00:42 AM(UTC)
by RepDry 9/23/2009 4:48:25 PM(UTC)
by lego1231 9/21/2009 8:18:43 AM(UTC)
Electric Kenmore Dryer not heating (Dryer Repair)
by morenojx 9/2/2009 7:32:58 AM(UTC)
