albertdiaz
#1 Posted : Wednesday, August 27, 2008 2:15:23 PM(UTC)
albertdiaz
My washer will stop working an show an f1 code. What is this code? We have to push stop and start bottons before it will start working. Would like to know if a part is going-out so I can have it replaced.
libertyappl
#2 Posted : Wednesday, August 27, 2008 6:11:06 PM(UTC)
libertyappl
This is what Whirlpool (which is who makes the 110 series) says about a F1 code:
F then 1 flashes when the control detects an
out of range pressure signal.
➔ Check pressure hose connection from tub
to machine/motor control. Is hose pinched
or kinked?
➔ If F then 1 repeats numerous times after
POWER is pressed and the pressure hose
connection is not pinched or kinked,
replace the machine/motor control.
Hope that helps
Nat
Replaced both Membrane Front Panel and Control Board - Still getting F1 Code (Oven Repair (including Ranges and Cooktops))
by StanJ55 3/7/2017 7:52:59 AM(UTC)
Maytag oven with F1 code (Oven Repair (including Ranges and Cooktops))
by Bwhite 6/28/2015 10:46:23 AM(UTC)
Whirlpool Bravo Washer Has F1 Code (Washer Repair)
by stargazer4591 4/7/2015 7:42:35 AM(UTC)
My Frigidaire Electric Range is showing F1 Code. (Oven Repair (including Ranges and Cooktops))
by smieri6 7/20/2013 9:45:09 PM(UTC)
Oven: F1 code (Oven Repair (including Ranges and Cooktops))
by a029342 7/1/2013 5:44:23 AM(UTC)
Amana F1 Code (Oven Repair (including Ranges and Cooktops))
by alongwalk 3/17/2013 1:59:18 PM(UTC)
Advantium 240 Above Range F1 Code (Microwave Repair)
by cooldaddyo 1/20/2013 7:35:58 AM(UTC)
LG / F1 code (Oven Repair (including Ranges and Cooktops))
by pipeliner11 12/1/2012 5:07:05 AM(UTC)
Maytag epic z F1 code, Ive replaced 2-ccu (Washer Repair)
by 84capri 6/26/2012 10:49:30 AM(UTC)
Kenmore Range E2F1 code...please help (Oven Repair (including Ranges and Cooktops))
by tferraro 1/9/2012 7:36:49 AM(UTC)
Kenmore Oasis Washer F1 code (Washer Repair)
by sofedup 1/2/2012 8:18:51 AM(UTC)
f1 code (Washer Repair)
by 4truckingup 9/5/2011 9:12:20 AM(UTC)
Cabrio Washer Showing F1 Code (Washer Repair)
by gsmith 8/9/2011 8:00:57 AM(UTC)
F1 code appears (Washer Repair)
by slcohen61 5/30/2011 10:03:49 AM(UTC)
by jcorsent 4/19/2011 8:59:39 AM(UTC)
