My washer will stop working an show an f1 code. What is this code? We have to push stop and start bottons before it will start working. Would like to know if a part is going-out so I can have it replaced.
This is what Whirlpool (which is who makes the 110 series) says about a F1 code: F then 1 flashes when the control detects an out of range pressure signal.
➔ Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
➔ If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control. Hope that helps Nat
