I'm getting the F1 code on my washer the parts book said its the metering control board, also it said to check the pressure hose. My question is that the water hose comming from my dom. water supply? I would like to know what to check before I order the control board. PS if there is any thing else I should check please advise. Thank You for your time. Joe C.
Hi Joe
The tech sheet on your model, if you have not already found it, is under the top. It will take you through the process of putting your machine in a diagnostic mode, but if it will not go into a diagnostic mode then the CCU is likely the problem.
If you buy from this site and the new CCU does not fix the problem, you can return it, see the returns policy for details and conditions.
I looked under the cover and there is nothing tellining me how to troubleshoot. Joe
