jcorsent
#1 Posted : Tuesday, April 19, 2011 8:59:39 AM(UTC)
jcorsent
I'm getting the F1 code on my washer the parts book said its the metering control board, also it said to check the pressure hose. My question is that the water hose comming from my dom. water supply? I would like to know what to check before I order the control board.
PS if there is any thing else I should check please advise. Thank You for your time. Joe C.
sidfink43
#2 Posted : Thursday, April 21, 2011 5:38:41 PM(UTC)
sidfink43
Hi Joe
The tech sheet on your model, if you have not already found it, is under the top. It will take you through the process of putting your machine in a diagnostic mode, but if it will not go into a diagnostic mode then the CCU is likely the problem.
If you buy from this site and the new CCU does not fix the problem, you can return it, see the returns policy for details and conditions.
jcorsent
#3 Posted : Monday, April 25, 2011 1:05:18 AM(UTC)
jcorsent
I looked under the cover and there is nothing tellining me how to troubleshoot. Joe
sidfink43
#4 Posted : Monday, April 25, 2011 4:23:30 AM(UTC)
sidfink43
Well darn, but here is a link to the Whirlpool Service Manual for your model.
https://secured.whirlpoo...540a8f/$FILE/8178582.pdf
Replaced both Membrane Front Panel and Control Board - Still getting F1 Code (Oven Repair (including Ranges and Cooktops))
by StanJ55 3/7/2017 7:52:59 AM(UTC)
Maytag oven with F1 code (Oven Repair (including Ranges and Cooktops))
by Bwhite 6/28/2015 10:46:23 AM(UTC)
Whirlpool Bravo Washer Has F1 Code (Washer Repair)
by stargazer4591 4/7/2015 7:42:35 AM(UTC)
My Frigidaire Electric Range is showing F1 Code. (Oven Repair (including Ranges and Cooktops))
by smieri6 7/20/2013 9:45:09 PM(UTC)
Oven: F1 code (Oven Repair (including Ranges and Cooktops))
by a029342 7/1/2013 5:44:23 AM(UTC)
Amana F1 Code (Oven Repair (including Ranges and Cooktops))
by alongwalk 3/17/2013 1:59:18 PM(UTC)
Advantium 240 Above Range F1 Code (Microwave Repair)
by cooldaddyo 1/20/2013 7:35:58 AM(UTC)
LG / F1 code (Oven Repair (including Ranges and Cooktops))
by pipeliner11 12/1/2012 5:07:05 AM(UTC)
Maytag epic z F1 code, Ive replaced 2-ccu (Washer Repair)
by 84capri 6/26/2012 10:49:30 AM(UTC)
Kenmore Range E2F1 code...please help (Oven Repair (including Ranges and Cooktops))
by tferraro 1/9/2012 7:36:49 AM(UTC)
Kenmore Oasis Washer F1 code (Washer Repair)
by sofedup 1/2/2012 8:18:51 AM(UTC)
f1 code (Washer Repair)
by 4truckingup 9/5/2011 9:12:20 AM(UTC)
Cabrio Washer Showing F1 Code (Washer Repair)
by gsmith 8/9/2011 8:00:57 AM(UTC)
F1 code appears (Washer Repair)
by slcohen61 5/30/2011 10:03:49 AM(UTC)
Water valve noise and F1 code (Washer Repair)
by dayb2000 3/7/2011 10:02:38 AM(UTC)
