Freezer will not freeze. Had it in storage about 2 months. I did put it on its side for about 30 minutes. I know you are not suppose to do it, but only way to get it home. Is there any way to fix that, if that is the problem? It did work fine before putting in storage. Please help me. Thanks
You can put it on its side, but then you have to keep it upright for about 24 hours before plug it in.
Try to unplug it for a day and then plug it in. Hopefully there is nothing serious happened yet.
Originally Posted by: Gene  You can put it on its side, but then you have to keep it upright for about 24 hours before plug it in.
Gene. It has been about 3 days or so that it has been unpluged. I will move it back into the garage and see what happens. Does this model suppose to have a fan? It does not have one that I can see at least. I did purchase a used one also and it was freezing when I saw it. Then put into truck, had to lay it down for few seconds to get on, but then put straight up and the same to get it off the truck. It was freezing, but when I went to check on it about 3 hours later, it was totally defrosted. At this point it would not refreeze, even tried to plug into a different plug. I saw the fan running and the black thing was hot by touch. I do not know what the model # is or the brand. Just was wondering in general what it could have been? It was an older model. Thanks so much for your time in this matter. I will let you know what happens on the other one soon.
Quote:... Does this model suppose to have a fan?... No, there are no fans in this freezer. Gene.
It works now finally, guess I just need to be more patient. Thanks so much for your help.
