Rank:: Member
My side-by-side Frigidaire refrigerator has a freezer that stopped freezing. It makes a high pictched squeak which happened more frequently after adjusting the thermostat (colder). Suggestions?
Here is the parts breakdown. Replacement parts for FRS26LR5CWO models | AppliancePartsPros.comWould help if you could identify what is making the squeak. Also is the compressor running? Is it cycling? Is the condenser fan running? I would start with the evaporator fan in the freezer section. Perhaps it is running very slow or intermittent and is not pulling air through the evaporator coils to cool it. |
THIS FORUM IS DEAD!!!!!!! |
