darrellwass
#1 Posted : Friday, October 21, 2011 6:59:02 AM(UTC)
darrellwass
The fridge is very cold on this unit, and will freeze food if turned up over "4" in the settings. Freezer will only freeze food about 1/2 of the day. I thought it might be the defrost timer, but I replaced that, and still have the same problem. What else could be causing this?
Thanks in advance,
Darrell
#2 Posted : Saturday, October 22, 2011 3:29:10 AM(UTC)
Measure the freezer temperature and post, for a fridg running constantly, it should be well below 10 degrees.
darrellwass
#3 Posted : Saturday, October 22, 2011 3:14:19 PM(UTC)
darrellwass
Thanks for your reply, but the fridge doesn't run constantly, it cycles on and off normally and maintains a constant temp in the fridge, it is just that the freezer doesn't stay cold. I replaced the defrost timer, so I am guessing it is the defrost thermostat. That part has been discontinued however.
#4 Posted : Sunday, October 23, 2011 12:48:13 AM(UTC)
Remove the back freezer panel and describe the frost pattern, should be completely frosted with light frost.
darrellwass
#5 Posted : Sunday, October 23, 2011 6:30:52 AM(UTC)
darrellwass
I took the panel off, and no frost in the freezer
#6 Posted : Sunday, October 23, 2011 5:39:54 PM(UTC)
Wait till the compressor starts running again, then check.
