blancapaloma5290
#1 Posted : Friday, August 13, 2010 11:42:02 AM(UTC)
blancapaloma5290
Freezer will not freeze. Had it in storage about 2 months. I did put it on its side for about 30 minutes. I know you are not suppose to do it, but only way to get it home. Is there any way to fix that, if that is the problem? It did work fine before putting in storage. Please help me. Thanks
#2 Posted : Friday, August 13, 2010 3:02:02 PM(UTC)
You can put it on its side, but then you have to keep it upright for about 24 hours before plug it in.
Try to unplug it for a day and then plug it in. Hopefully there is nothing serious happened yet.
blancapaloma5290
#3 Posted : Wednesday, August 18, 2010 5:47:04 AM(UTC)
blancapaloma5290
It has been about 3 days or so that it has been unpluged. I will move it back into the garage and see what happens. Does this model suppose to have a fan? It does not have one that I can see at least.
I did purchase a used one also and it was freezing when I saw it. Then put into truck, had to lay it down for few seconds to get on, but then put straight up and the same to get it off the truck. It was freezing, but when I went to check on it about 3 hours later, it was totally defrosted. At this point it would not refreeze, even tried to plug into a different plug. I saw the fan running and the black thing was hot by touch. I do not know what the model # is or the brand. Just was wondering in general what it could have been? It was an older model. Thanks so much for your time in this matter.
I will let you know what happens on the other one soon.
#4 Posted : Wednesday, August 18, 2010 1:17:51 PM(UTC)
Quote:
... Does this model suppose to have a fan?...
No, there are no fans in this freezer.
blancapaloma5290
#5 Posted : Thursday, August 19, 2010 6:04:14 PM(UTC)
blancapaloma5290
It works now finally, guess I just need to be more patient. Thanks so much for your help.
Whirlpool Top-Mount Freezer won't freeze (Refrigerator & Freezer Repair)
by Regalhank 11/29/2016 6:58:46 AM(UTC)
Freezer won't freeze after advancing defrost timer (Refrigerator & Freezer Repair)
by MightySky 7/8/2013 7:33:03 PM(UTC)
Upright Freezer won't freeze and makes loud noise (Refrigerator & Freezer Repair)
by Renatefry 2/20/2013 5:15:25 PM(UTC)
by Renatefry 2/20/2013 5:02:07 PM(UTC)
by shoman 3/24/2012 6:36:59 AM(UTC)
Freezer won't freeze, fridge not that cold (Refrigerator & Freezer Repair)
by otison 1/28/2012 10:26:29 AM(UTC)
frigidaire freezer won't freeze an fridge isn't cold as should be. (Refrigerator & Freezer Repair)
by auralight1 1/22/2012 8:07:33 AM(UTC)
by duncanj 10/30/2011 7:16:33 AM(UTC)
Fridge Cold, Freezer won't freeze all the time (Refrigerator & Freezer Repair)
by darrellwass 10/21/2011 6:59:02 AM(UTC)
Freezer Won't Freeze, Both Sides Stuck at @ 40ยบ (Refrigerator & Freezer Repair)
by obx166ec 10/7/2011 3:53:35 PM(UTC)
freezer won't freeze (Refrigerator & Freezer Repair)
by Gpa 4/28/2011 12:12:30 PM(UTC)
Refrigerator freezer won't freeze (Refrigerator & Freezer Repair)
by bittersweet 12/16/2010 10:53:30 AM(UTC)
Freezer Won't Freeze (Refrigerator & Freezer Repair)
by leichte 11/10/2010 3:13:48 AM(UTC)
freezer won't freeze anymore (Refrigerator & Freezer Repair)
by 1967hammer 9/6/2008 7:56:26 AM(UTC)
HotPoint Refrigerator's Freezer won't freeze (Refrigerator & Freezer Repair)
by RHCHomeowner 7/18/2008 7:02:39 PM(UTC)
