tsmith1928
#1 Posted : Thursday, August 12, 2010 5:56:52 AM(UTC)
tsmith1928
Side by side refrigerator door won't close but freezer door closes fine. Tried to adjust hinge but no luck. Can it be the door gasket?
applianceman
#2 Posted : Thursday, August 12, 2010 3:19:55 PM(UTC)
applianceman
There are two cams at the door hinge one mounted on the door hinge and one mounted on the door. If one or both of the cams are broken the door will not close properly. What that cam does is lift the door up when you open it so that when it closes it falls into place so to speak. That is the most common problem but yes if the door gasket is hanging it could cause the problem.
Refrigerator Door Repair Guide
tsmith1928
#3 Posted : Friday, August 13, 2010 8:11:06 PM(UTC)
tsmith1928
Thank you. I am in Glenview IL. Are you in the area?
applianceman
#4 Posted : Friday, August 13, 2010 8:21:27 PM(UTC)
applianceman
No, I live on the east coast.
Refrigerator door does not automatically close (Refrigerator & Freezer Repair)
by smateja@earthlink.net 11/10/2016 1:04:22 PM(UTC)
Advice on replacing Monogram refrigerator door gasket (Refrigerator & Freezer Repair)
by TerryY 10/14/2016 6:30:50 PM(UTC)
Refrigerator door seal (Refrigerator & Freezer Repair)
by chknmom 10/16/2015 3:57:27 PM(UTC)
Refrigerator door makes popping sound when opening and closing (Refrigerator & Freezer Repair)
by johnschwery 5/22/2015 8:27:41 AM(UTC)
GE Refrigerator door keeps hitting light switch (Refrigerator & Freezer Repair)
by pnorris411 11/2/2014 3:44:45 PM(UTC)
exterior of panel between the frezzer door and the refrigerator door is burning hot (Refrigerator & Freezer Repair)
by splash13 7/19/2014 7:44:36 PM(UTC)
Frigidare Refrigerator door handle loose (Refrigerator & Freezer Repair)
by dojoy 2/19/2014 1:53:04 PM(UTC)
Refrigerator Door Handle Loose (Refrigerator & Freezer Repair)
by Lauren57 10/30/2013 7:29:50 PM(UTC)
Frigidaire Refrigerator Door Sagging (Refrigerator & Freezer Repair)
by supermoose 4/5/2013 10:49:33 AM(UTC)
how to remove refrigerator door handle (Refrigerator & Freezer Repair)
by srace 1/6/2013 5:16:15 PM(UTC)
Maytag French Door Refrigerator Doors Not Staying Closed (Refrigerator & Freezer Repair)
by davej14 10/29/2012 6:59:55 AM(UTC)
no water from refrigerator door (Refrigerator & Freezer Repair)
by mike glazer 9/18/2012 6:50:51 PM(UTC)
Refrigerator door not closing tightly (Refrigerator & Freezer Repair)
by Lery 8/18/2012 12:18:40 PM(UTC)
refrigerator door seal (Refrigerator & Freezer Repair)
by Pablito Dos 8/12/2012 6:34:42 AM(UTC)
Refrigerator Door stop broken (Refrigerator & Freezer Repair)
by TheDickens 8/7/2012 11:04:56 AM(UTC)
