fgm7541
#1 Posted : Friday, August 6, 2010 2:46:50 PM(UTC)
fgm7541
:) HI,
I have Amana over 10 year Model Number BC21V1W, the freezer in the bottom and when ice collected and not deforst stop cooling and when I unplug and clean and plug again work all right for period of time then happen again and stop workking. do you think the thermostate freezer need to replace and is that Part AP4002415, please help me thank you
#2 Posted : Saturday, August 7, 2010 12:58:05 PM(UTC)
Replacement parts for BC21V1W models | AppliancePartsPros.com
[COLOR="Blue"]do you think the thermostate freezer need to replace and is that Part AP4002415[/COLOR]
Hard to say without further testing.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 342 in Section 9) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 43 in Section 5) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 23 in Section 5) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Cycles stop working intermittently (Washer Repair)
by sgaissert 5/23/2023 2:10:32 PM(UTC)
Maytag Gemini-ovens randomly stop working power interrupt error (Oven Repair (including Ranges and Cooktops))
by romdos 9/2/2018 5:11:08 PM(UTC)
Refrig/Freezer stop working suddenly (Refrigerator & Freezer Repair)
by japthorpe 7/8/2015 10:31:57 AM(UTC)
GE fridge compressor and water dispenser stop working at same time (Refrigerator & Freezer Repair)
by silver02ls1 4/27/2015 6:34:02 AM(UTC)
Intake drain dishwasher no stop working (Dishwasher Repair)
by Giu62 3/11/2015 10:34:05 AM(UTC)
Intermittant Issue -- Icemaker and Water / Icemaker Dispenser stop working (Refrigerator & Freezer Repair)
by GoVikings1 12/31/2014 2:33:47 PM(UTC)
Haier ice maker hot to touch, gears stop working (Refrigerator & Freezer Repair)
by Darlene Coleman 7/9/2014 10:28:55 AM(UTC)
Refriderator stop working (Refrigerator & Freezer Repair)
by Yuan 3/30/2014 11:46:57 AM(UTC)
Hotpoint Refrigerator & Freezer stop working (Refrigerator & Freezer Repair)
by Sam2628 4/27/2013 8:17:47 AM(UTC)
All Gas stove Ignitors stop working (Oven Repair (including Ranges and Cooktops))
by weeties61 3/21/2013 7:16:07 AM(UTC)
dryer stop working (Dryer Repair)
by howardr57 2/18/2013 10:08:28 AM(UTC)
Stop working at middle-circle (Washer Repair)
by langkhach2013 2/18/2013 8:06:09 AM(UTC)
GE Refrigerator just stop working (Refrigerator & Freezer Repair)
by garfish 10/21/2012 12:01:03 AM(UTC)
Fridge/freezer fans stop working (Refrigerator & Freezer Repair)
by peeples 9/4/2012 9:33:21 AM(UTC)
dryer doesn't stop working w/ door closed ( timer is bad ? ) (Dryer Repair)
by jose julio alves 6/12/2012 8:14:21 PM(UTC)
