My Maytag washer and dryer are just about 4 years old.I encountered my first problem since new today.The washer gets stuck between the 9-10 minutes mark and will not do anything but stay there.It does not shut off just freewheels at that mark.I tried to research this problem through the archives here but did not find anything with this particular model and problem.Thanks in advance.
Anyone? Shall I run it again and watch it through the whole cycle?
Question....What do you have in the washer? nat
I had a load of jeans and shirts.It did not spin out but I have an older set down stairs I used to finish the job.What would you suggest I load it with?
Hi Robert,
Look for the tech sheets inside the control panel and perform all tests recommended by the manufacturer. Post the results.
Just a lot of time the weight of the load can't balance that's exactly what it will do. I have one of these and have to watch washing blankets. quilts etc.
Gene. Gene,where is the control panel?? I looked for it on here and didnt find it.I ran it again today and pretty much the same happened.Its stuck in the drain cycle,repeating it over again and wont go into spin.
If it is what is described in the service builitin,is that something I can tackle or should a technition be called.
Robert,
Nobody knows it better than you.
